Disable IP Source Guard (IPSG) on a port to allow traffic from all IPv6 addresses to go through the port without being filtered.
enable
configure terminal
interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
no ipv6 source-guard enable
show ipv6 source-guard interface gigabitEthernet [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Disable IPSG on port 1/1.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitEthernet 1/1 Switch:1(config-if)no ipv6 source-guard enable
Verify the configuration.
Switch:1(config-if)#show ipv6 source-guard interface gigabitEthernet 1/1
Slot/Port  Source Guard  Number of  IPv6  Address
             Mode        address allowed  overflow count
1/1          Disabled          10          0
